brilliant VHD recovery tool
VHD recovery is a brilliant VHD recovery tool that can recover VHD files completely after an event of corruption or data loss. It scans the FAT and NTFS file systems of the virtual hard disk and recovers the corrupt, damaged or lost files. It has got three inbuilt scanning modes: Quick Scan, Extensive Scan and File Trace. This software Supports all Windows platforms like Windows 8, Windows 7, Windows Vista, Windows XP, Windows 2000, Windows 2003, Windows Server 2008/R2.
See full info :- http://www.undeletepcfiles.com/vhd-d...very-tool.html
Recently I got to know a vhd recovery tool that gives simple and fast solution for recovering vhd file data from corruption. This software is also capable of getting back deleted or lost data from VHD.
Read more:- Restore VHD Software Effectively Repair Corrupt & Damaged VHD Files
How to recover VHD file data?
Another smart way to repair corrupt VHD file is VHD Recovery tool provided by SysInfoTools Software. The software is programmed for handling high level of corruption in VHD files created by using Backup and Restore tool on Windows Vista and 7. Also, it supports VHD files created for Virtual machines by Disk Management feature of Windows system. It has many salient features which will help users recover their maximum possible data from corrupt VHD files.
Some of the key features are shown below:
For more information, you can visit: www.sysinfotools.com/recovery/vhd-recovery.php
Thanks and best regards.
- It supports both dynamic and fixed disk types;
- It supports both popular partition tables, i.e. MBR and GPT;
- It supports all popular file systems, such as: FAT, FAT16, FAT32, FAT64 & NTFS of Windows, HFS+ of Mac, and EXTX of Linux;
- Two scanning modes, i.e. standard and advanced, for different level of corruption;
- Three different recovery modes: Standard, Advanced and Deep;
How to repair VHD file?
Before using any paid software, you must try few easy manual tricks which don't require any 3rd party tool or any other cost. The manual tricks include running a script in Windows PowerShell that will help you mount the VHD file in the root folder, and you can run a CHKDSK on it. You can also try to create a new Virtual Machine, add the corrupt Virtual disk file to it and then compact it. Microsoft also provides VHD tool that can repair VHD file. You can read the blog post shared below for more information:
Repair VHD File Manually – Utmost Solutions for VHD Recovery | N. Sem's Blog
Virtual Machine Data Recovery Tool provides effective and quick solution to recover data from corrupt VHD,Software which can can fix both FAT and NTFS file systems on virtual hard disk (VHD) created using Microsoft's virtualization solution. This software handles all issues related to accessibility or use of Windows Hyper-V VHD files easily.
See More Info:- Virtual Machine Data Recovery Tool to Recover Lost & Deleted data from Virtual Machine.
If you have corrupt VHD file, you should try professional VHD Recovery software. This is the ultimate solution to repair VHD file and to recover your maximum possible content from it. It's available with demo version for free evaluation. So before you can purchase the software, you must download its free demo version. By using demo version, you can check the preview of your data which you can actually recover from the corrupt VHD file before paying for the software.
Or if you're looking for free solution, you should refer to this blog post - Repair VHD File to Restore Your Invaluable Data From It
There are few easy manual tricks shared in the above blog post which you can try to repair VHD file. I hope the shared information would be helpful here.
