How to Restore Lost Data on iPhone 6 After iOS 9 Upgrade
Old 10-07-2015, 03:04 AM
menfie's Avatar
Default How to Restore Lost Data on iPhone 6 After iOS 9 Upgrade
Download iOS 9, 9.0.2 And Install On iPhone 6, 6 Plus, 5s, 5c, 5, 4S, iPad, iPod touch
Before installing iOS 9 / 9.0.2, it’s highly recommended to make a complete backup of your device to either iCloud or using iTunes to your computer. We have separate detailed guide on how to make the backup and prepare your device for iOS 9 that you can check out here. Once you are done with making backup using the instructions provided at that link, follow the instructions below to install iOS 9 / 9.0.2 on your device.
More and more iPhone 6 users can not wait to update their ios devices to the lastest iOS 9,before upgrading the iPhone 6 to iOS 9,you may need to know what ready to do before update iPhone to iOS 9.
Are you can't wait to upgrade you iPhone to the latest iOS 9? It sounds really exciting! However, so many examples told us that lots of users lost theirs iPhone data during or after iOS 9/iOS 8 upgrade, ever if they have did some backup before the update. Don't want to lose your data from iPhone, or just wanting a way to recover data from iPhone 6 after iOS 9 upgrade? Please keep reading the following article.
iPhone 6 Data Recovery which also named as iOS 9 Data Recovery software, is an all-in-one yet professional data recovery program which allows you to regain your lost or deleted data from iPhone, as well as iPhone and iPod touch in one click with three simple ways.
Way 1. Restore Lost Data from iPhone 6 Directly
Way 2. Recover iPhone Data from iTunes Backup
Way 3. Retrieve iPhone Data from iCloud Backup
How to Retrieve Lost Data from iPhone 6 directly after Upgrading to iOS 9?
Step 1.Run the program and connect your phone to computer
After downloading the program, you need to connect your iPhone to PC/Mac with USB cable. Then the primary window will come up if it detect your iPhone 6, follow its order to click “Start Scan”.
Step 2.Start to scan your iPhone device for lost messages
After step 1, you are allowed to start scan with iPhone Data Recovery. Wait for few minutes, the result will come out as picture below.
Step 3.Preview and Recover text messages from iPhone directly
All your documents is on the left of interface. Open and preview each file you may need, select and check those you want to backup or recover. For example, if you want to recover text Messages, tap “messages” on the left side of the interface to preview and choose them, which contain names, phone numbers, chat contents, and attachments. After you select what you want, click “Recover” button, then the program will begin the recovering process
So, no matter you lost your data from iPhone due to iOS upgrade, iOS downgrade, iOS jailbreak, accidently deletion, factory settings restore, water damaged, system crashes, etc., iPhone Data Recovery software is your best and most reliable solution to retrieve your lost data.
If you have buy a new iPhone 6s/iPhone 7,you can use this iPhone data transfer or Phone to Phone Transfer to transfer data from old iPhone to new iPhone.
If you use Android Samsung Galaxy smartphone before,please read this use guide to transfer data from Samsung Galaxy to iPhone 6s.
Read more from: Recover iPhone Data After iOS 9 Upgrading
https://recoveriphoneios9.wordpress.com/
Old 10-20-2016, 10:48 AM
semder1's Avatar
If you don't sync the phone with iTunes before and have not backup on iCloud before, you can use iPhone 6 data recovery to scan your phone and recover lost data from iPhone 6 directly, it also support to extract iTunes/iCloud backup, you can choose one of the ways you needed.
Old 05-15-2018, 04:38 AM
xuzen21's Avatar
If you turn on the automatic synchronization feature on iTunes, when you connect iPhone to iTunes, it will sync all iPhone data, when you lost or delete data on iPhone, you can check whether you backup them in iTunes, the iPhone data recovery tool can help you to extract iTunes backup to preview all data in detail, then you can check the delete data and restore lost data from iPhone. If you don't make a backup, you can use it to directly scan your phone to get data back.
how to restore deleted iPhone calendars
how to recover deleted reminders on iPhone
Old 01-01-2019, 07:29 PM
alansmith's Avatar
You need to use iPhone Data Recovery. It can scan your iPhone deeply to find the deleted and lost data for you. You can preview them before recovering. Learn how to recover lost text messages on iPhone 6. Besides messages, you can also recover photos, videos, contacts, call history, notes, reminders, calendars, voice memos, voicemail, safari bookmarks, Whatsapp messages and other deleted and lost data for you.
niejun
05-17-2022 09:02 PM
niejun
12-02-2018 06:54 PM
niejun
11-22-2018 07:16 PM
niejun
11-20-2018 07:39 PM
Quick Reply: How to Restore Lost Data on iPhone 6 After iOS 9 Upgrade
