convert edb to pst
Old 12-11-2014, 10:38 PM
DamianHiggins's Avatar
Default convert edb to pst
EDB to PST Converter software is an adroit software that allows you to conveniently convert user mailboxes of Exchange EDB files to Outlook Personal Folders (PST) files. The software converts your EDB to PST without making changes to the original database, thus providing a clean and absolute conversion. This ensures high availability of your mail data even in Exchange Server downtime situations or at times when you require migrating to a completely new work environment.
In the online mode, the software enables you to connect to a single user mailbox or all mailboxes on the Exchange server. In order to carry out online conversion, you must log on to your domain computer with full 'Administrative' privileges. After establishing a connection to the Exchange Server, the software allows you to convert connected user mailboxes to PST files.
While working in online mode, you can convert individual items in your mailbox to either 'EML' or 'MSG' files. With this competent tool, you can preview the contents of your Exchange database before conversion and choose to recover only specific mailboxes from the EDB file. The option to preview mailbox data gives you a clear idea about the efficacy of this software. Additionally, the choice of 'selective conversion' makes it easy for you to perform mail conversion within the least possible time.
The software has a more comprehensible approach to offline EDB conversion. With the advanced search functionality, you can easily find offline EDB files stored anywhere in your system, including folders, sub-folders, and entire drives. You can select your version of Exchange Server and then scan the EDB file to extract various user mailboxes.
You can save these mailboxes at a desired location as PST files. The software is equipped to restore your accidentally deleted Exchange mailboxes (existing within the 'Mailbox Retention Period') in the offline mode. It also includes support for the offline conversion of 'PUB.EDB' files.
Key Features:-
* Extracts EDB mailboxes to importable PST files
* Offers flexibility to convert working (online) EDB files to PST/EML/MSG
* Supports selective conversion of files
* Supports MS Exchange 2010, 2007, 2003, 2000 and 5.5 versions
* Support for MS Office ( 64 bit)
* Support for PUB.EDB files for 'Offline' conversion
Download :- EDB to PST Converter – Repair & Convert EDB Mailbox to PST File
Old 12-13-2014, 04:19 AM
abelmartin002's Avatar
Recoverydatatools – Exchange EDB to PST converter utility quickly repair damage EDB file and securily open Exchange EDB file. This tool recover EDB file to PST file format with original coding HTML, TXT, RTF. You just simply export Exchange EDB to PST exporter tool. See more at here: - EDB to PST conversion tool to recover and convert multiple mailboxes from EDB files to PST files format also read this post: EDB to PST Converter Tool
Old 12-15-2014, 01:26 AM
EugeneMorris's Avatar
Also try EDB to PST Converter Tool for fast Exchange EDB to PST conversion without any difficulty. This EDB to PST Tool maintains data integrity when convert Exchange EDB to PST.
Read more:- http://www.filesrepairtool.com/edb-to-pst-converter.html
Old 12-17-2014, 03:36 AM
Merry Fair's Avatar
Perfectly converts EDB data to PST and also performs recovery of the EDB data by using RecoveryFix for Exchange Server Recovery (EDB to PST) Converter Software. For any information visit here :- EDB File - Repairs Severely Correupted & Damaged Exchange EDB Files and EDB to PST File Conversion With Deleted Items from Exchange Server Database Folders
Old 12-21-2014, 11:06 PM
Sennie Loiuce's Avatar
Default Exchange Database Recovery
Best Exchange database recovery tool helps you to repair corrupt Exchange database and recover data form Exchange EDB file along with whole mailbox attachments. By this software you can import Exchange to Outlook and read emails of EDB with entire email properties. In every Exchange version it gracefully runs and perfectly open Exchange database in Outlook with accurate formats.
Read More: Exchange EDB Recovery Tool Safe to Recover Exchange EDB to PST
Old 12-29-2014, 04:20 AM
Ronal Dimaro's Avatar
I would like to suggest use EDB to PST converter software that easily sort out your exchange server database corruption error and quickly convert EDB to PST files with extract all email folders such as- Inbox, Outbox, Sent items, Journal, Contacts, Calendars, Reminder, Application, Appointment, Notes, Task, Deleted items etc. The software supports all version of exchange server and ms outlook. Read more http://www.repairexchange.org/
Old 01-05-2015, 04:47 AM
JamesMarlow's Avatar
EDB to PST converter tool gracefully repair damage EDB file and transfer data from EDB file to PST file format. It nicely migrate Exchange EDB file to PST file format along with mailbox folders. To know more see this site:- http://www.recoverfilesdownload.com/edb-to-pst-converter.html
Old 01-18-2015, 11:38 PM
Default Exchange EDB to PST
This effective Exchange EDB to PST migration tool facilitates good migration of corrupted EDB file into PST file with each and every Exchange mailbox database. In every EDB file version it runs gracefully and transfer data from EDB to Outlook up to 2013. It performs masterly over corrupt EDB files and successfully open Exchange database in Outlook PST file.
Read More: https://www.facebook.com/exchangeedbrecoverytool
Old 06-03-2015, 01:39 AM
Angel Marino's Avatar
Default EDB to PST converter
Exchange server mailbox recovery software can instantly convert corrupt exchange server edb files into healthy pst files. The software restores mailbox items and repair corrupt exchange server database without hassle. I would like to refer http://www.exchangeservermailboxreco...topstfile.com/ for more help.
  #10
Old 06-18-2015, 04:32 AM
Get best EDB converter tool that helps you to repair corrupt EDB file data and convert EDB file to PST file smartly. You can solve every queries related "how to recover EDB and how to convert EDB to PST" with the help of EDB file converter program. This Software works on whole versions of Exchange file and shift EDB to PST file. Get Microsoft Exchange EDB export to PST utility for successfully repair EDB file and export Exchange EDB to PST, EML, MSG and HTML file formats. This is a wonderful tool that works on all Exchange versions up to 2013.
Read More: http://www.exchangeexport.edbtopstsoftware.com/
Quick Reply: convert edb to pst
