Lotus Notes NSF to PST
Old 05-12-2016, 08:09 AM
jsen's Avatar
Default Lotus Notes NSF to PST
Software available at eSoftTools for NSF to PST conversion, immediately download if you required to convert data from NSF file to MS Outlook because it will really work for you with excellence and able to give 100% satisfaction. This software supports all Lotus Notes version and effortlessly convert NSF to PST, EML and MSG format.
Read More
NSF to PST Conversion|Convert NSF to PST|NSF to PST Converter
Old 06-20-2016, 07:09 AM
mikeswan's Avatar
Indeed, NSF to PST converter is an efficient application to migrate Lotus Notes database to Outlook platform. So, users can use Kernel for NSF to PST converter software that impeccably converts NSF file to PST, Text, HTML and RTF format. This tool transfers NSF mailbox like messages, attachments, appointments, images, notes, journals, address books, tasks and additional folders.
See more : Notes to Exchange Migration Software - Migrate Lotus Notes to Outlook
Old 07-31-2016, 11:47 PM
Rawatsonika4u's Avatar
Banned
Is your Outlook Email client application is unable to open and read NSF file of IBM Lotus Notes Email client application due to supporting different file format and need to access NSF file in Outlook email client? If you want to act in Outlook email client application with NSF file then visit: NSF to PST Converter
Old 08-01-2016, 12:40 AM
JohnBrooks's Avatar
Banned
Use NSF to PST Converter software which can easily migrates your entire database in same hierarchy with no any single bit of data alterations having multiple .nsf files into .pst file format.This utility comfortably converts whole attachments, emails, images, journals, address book, tasks, appointments, notes, etc. See more: NSF to PST Converter – An Expedient Tool for Lotus Notes to Outlook Migration
Old 10-08-2016, 06:28 AM
anialex's Avatar
If you are looking for best NSF converter tool, download from eSoftTools that gives you safe conversion NSF file to PST file, EML, MSG format. Software has great ability to know how to convert lotus notes to Outlook secure fully. versions of Lotus Notes NSF and Outlook file.
Read More:
NSF PST Converter | Import,Convert NSF to PST
Old 10-10-2016, 12:21 AM
James Britton's Avatar
For a quick conversion of Lotus Notes to Outlook, you should try to use any perfect NSF to PST Converter that can easily convert all NSF file into an Outlook PST file format. But here I am giving you NSF Conversion manual method technique that is freeware and available at: NSF to PST Converter
Old 10-13-2016, 01:04 AM
anialex's Avatar
Old 07-13-2017, 03:28 AM
There is a manual method for transferring Lotus notes data to MS Outlook, using Export/Import feature in Lotus Notes or MS Outlook, but this method is very complicated and becomes very tedious if large amount of data needs to to transferred.
Whereas using NSF to PST Converter is very easy, quick and precise. This conversion tool can even convert encrypted NSF files into PST files.
To learn more about both the methods, visit: https://sysinfotools.com/blog/how-to...to-pst-format/
Old 12-23-2017, 05:30 AM
  #10
Old 12-28-2018, 01:43 AM
Kinsladdam's Avatar
Now safe and secure converter software easily free download This NSF to PST Converter Software for convert NSF database into PST or additional format with all mails, contact, media, attachment or properties such as -to, Bcc, Cc, date etc. without any difficulty or errors. This application step all version of Lotus Notes 9.1, 9.0, 8.0, 8.5 ,6.5 and below versions.
More Info :- https://sites.google.com/view/how-to...e-to-outl/home
Quick Reply: Lotus Notes NSF to PST
