Install question for aftermarket Nav
Does anyone know where/how the amp is wired for an 02 Cab that is going to have a Pioneer AVIC D3? Also is the antenna amplified on that car?
RE: Install question for aftermarket Nav
most likely the amp is wired with a low level signal in a smal plug behind the radio, cut the plug because the grounds of the audio signal are all connected together (the brown wires) also the antenna wire is white i think on porsches, and you might be lucky to have the speed pulse wire back there also, off the top of my head it is gray/pink I think
thanks alot for response
One other question is how doesmy double din PioneerAVIC D3 stay mounted. What holds the unit in and keeps it from sliding out? I probably should have said earlierthat im moving the ac unit down in the cd holder area.
