Remove Cayenne Radio
How do you remove the Cayenne Radio????
RE: Remove Cayenne Radio
Remove bezel around radio, snaps hold this in. There is one 7mm on left side of radio that has to be loosened not removed then there are 4 hex heads 2 on each side of radio right behind face. Loosen about 1/4 turn each one thenav/radio will slide out
check this out...
| All times are GMT -5. The time now is 09:35 AM. |
