How To...wash Mike and Ray's Dirty Microfiber Towels
One of the perks of working at Autogeek (besides having access to Max's AMG at any time), is the ability to take full advantage of the "Show Car Garage" on your day off, or for the occasional Thursday Night Extreme Makeover. Needless to say, we go through quite a few microfiber towels. With the recent introduction of Wolfgang Microfiber Cleaner and Rejuvenator, and what can only be described as a mound of dirty microfiber towels in the Show Car Garage, I decided this would be perfect opportunity to demonstrate the latest and greatest microfiber detergent from Wolfgang.
http://autogeekonline.net/nick/Wolfg...ejuvenator.jpg Wolfgang Microfiber Cleaner and Rejuvenator is the first and only microfiber detergent formulated with the HE washing machine in mind. Wolfgang Microfiber Cleaner and Rejuvenator is a specially formulated detergent that deep cleans microfiber towels and tools, effectively removing oily and greasy residues. Wolfgang Microfiber Cleaner and Rejuvenator preserves the soft texture and unique absorption qualities of microfiber towels and tools. Highly concentrated formula only requires an ounce or two depending on the size of the load! Load one: http://autogeekonline.net/nick/Wolfg...r/IMG_0316.JPG Didn't anyone tell Ray that Guzzlers aren't for cleaning wheel wells? http://autogeekonline.net/nick/Wolfg...r/IMG_0317.JPG How it works Wolfgang Microfiber Cleaner and Rejuvenator is formulated using a complex blend of surfactants, emulsifiers, and water softeners. The clean-rinsing formula was formulated to be safe for use in all washing machines, including high efficiency (HE) washing machine models. Wolfgang Microfiber Cleaner and Rejuvenator is highly concentrated, so you only need an ounce or two depending on the size of the load. The 16 ounce bottle features a cleverly designed built-in measuring cup to ensure that you use the proper amount based on the size of the load. http://autogeekonline.net/nick/Wolfg...%20machine.jpg After determining the size of the load, set the temperature to "Hot Cold" http://autogeekonline.net/nick/Wolfg...r/IMG_0323.JPG Set to "Heavy Cycle" and turn on machine http://autogeekonline.net/nick/Wolfg...r/IMG_0321.JPG Toss your microfiber towels in the washing machine http://autogeekonline.net/nick/Wolfg...r/IMG_0327.JPG The 16 ounce bottle features a cleverly designed built-in measuring cup to ensure that you use the proper amount based on the size of the load. 1 ounce for small loads, and 2 ounces for larger loads. http://autogeekonline.net/nick/Wolfg...r/IMG_0331.JPG http://autogeekonline.net/nick/Wolfg...r/IMG_0335.JPG http://autogeekonline.net/nick/Wolfg...r/IMG_0334.JPG Greasy, oily stains don't stand a chance against Wolfgang Microfiber Cleaner and Rejuvenator http://autogeekonline.net/nick/Wolfg...r/IMG_0340.JPG If you own an HE washing machine or if you're looking for a new microfiber detergent, be sure to check out Wolfgang Microfiber Cleaner and Rejuvenator. A special thanks to Mike Phillips for his excellent photography skills. Wolfgang Microfiber Cleaner and Rejuvenator |
