Stains in carpet, mats, and seats?
Wolfgang Spot Eliminator Wolfgang Spot Eliminator is the answer to your vehicle's toughest spots and stains. Armed with industrial strength cleaning agents, Wolfgang Spot Eliminator deep cleans auto carpet and upholstery and helps repel future stains. Give your car's interior a blast of superior cleaning power with Wolfgang Spot Eliminator.Tough stains and stubborn, ground-in dirt don't stand chance! BEFORE http://lib.store.yahoo.net/lib/autog...ttersonly1.jpg AFTER http://lib.store.yahoo.net/lib/autog...ttersonly2.jpg http://ep.yimg.com/ca/I/yhst-5986010...2269_243145861 Wolfgang Spot Eliminator is formulated to act fast and leave nothing behind. This blend of industrial strength, water-based cleaners and German super polymers works to eradicate stains and protect the carpet and upholstery from future stains. Wolfgang Spot Eliminator removes the most difficult stains like food, soda, perspiration, ink, gum, grease, and much more. Carpet, mats, and seats are left looking and feeling completely clean. Wolfgang Spot Eliminator works by sequestering grease, oils, and dirt away from the individual fibers. As you agitate with a brush, these particles are released from the fibers and held suspended until you blot them away with a towel. This type of cleaner is gentle on carpet and upholstery fibers, and it doesn't leave a sticky residue. While the cleaners are hard at work, German super polymers bond to the fibers to shield them from spills and stains. Future cleaning is made easier with Wolfgang Spot Eliminator. Wolfgang Spot Eliminator can be used on virtually any surface, including the dashboard and door panels. The water-based cleaners are safe and gentle on plastics as well as fabrics and carpet. Directions: 1. Vacuum affected area first to remove all loose particles. 2. Spray Wolfgang Spot Eliminator directly on the stain. Allow cleaner to sit and penetrate for 20-30 seconds. 3. Agitate with a brush or damp sponge. 4. Pat dry with a clean microfiber towel. 5. For extra tough stains, a second application may be necessary. http://site.wolfgangcarcare.com/page-art/se-1.jpg WOLFGANG SPOT ELIMINATOR |
I need that upholstery cleaner which can clean the seats from deep and don't damage the fibers of the carpet.
You can minimize the need to clean your carpet by regularly vacuuming your carpets. Vacuuming removes dirt, which otherwise can accumulate in your carpet and become hard to remove. So you should hireProfessional Carpet Cleaning Bethesda for clean your carpets.
First gently rub the stain with hot water and then spray over the carpet cleaner to remove the stains.
Awesome information
I've never used this cleaning product, but it seems to be pretty cool.
I hope it is as good as you were trying to present it to us. Cleanness is indeed essential, and therefore I'd like to share something with you. Probably, you would agree that there is nothing more challenging than cleaning the grouts. Luckily, I found the solution. The easiest way to clean the grouts is by hiring a professional tile and grout cleaning service. At least I used to hire a professional tile cleaner when I need to clean my bathroom, and thus I can save energy time and still get the best result. |
