911 2.4 S Cyl Heads
I need to replace my 2.4 S cyl heads PN 911 104 307 1R Aug-1972
I purchase a old set of cyl heads PN 911 104 302 0R Sept-1971 the camshaft cover is the same number on both heads. I assume that the 1971 heads are for a 911 2.2 S . Do I have to modified the 1971 heads to fit on my 1972 car ? Are the valves the same size on both cars ? Do I need to bore only the heads contact surface to the cylinder liner , since the 1972 car is fitted with pistons maybe with bigger bore ? TKS Marco |
