Washing your car with a pressure washer?
Hey everyone,
Does anyone have any suggestions on what to and not to do when washing your car with a pressure washer? And also anyone have a clue on what is a good PSI to wash your car with? Thanks in advance! |
Always remember that building your own boat doesn't encourage building it by yourself alone. Of course you'll need help once in a while. Building your own boat means you make the output as you please. You can hire craftsmen to do the labor work. The most important thing in here is that it is done as you pleased, as you designed it to be.
If you have you own car then you should have to take care of it like you should clean and wash it regularly.There are many stores from where you can buy car washing machine.
Hi folks,
You can purchase both electric and gas-powered pressure washers. In general, gas pressure washers have a much stronger cleaning capacity and are too strong for light jobs, such as washing a car or truck. In order to avoid damaging your vehicle, it is better to use an electric pressure washer set at the appropriate PSI. |
