1983 944 DME relay or ECU? HELP
Hello to all,
I am new, and also in need of some advice. I just purchassed a 83 944 the day it arrived it ran fine, the following day I was driving it home, and it just died on me (of course my luck it was raining). It wouldnt start up right away (all it would do is turn over). I waited about ten minutes and it started with no problem. The folowing day I drove to my shop with no problems, about 2 hours later I went to leave, and it just turned over, and over without starting? Just before having it towed I checked it over with a volt meter, and there was no spark from the coil. Now the car is at a local repair garage where it has been for the last 2 weeks. The coil has been changed, and now the garage tells me that it wont turn over now? The Porsche dealership I spoke to told me it sounded like the DME relay? Then again anothe guy tells me it needs a new ECU? If anyone could help me with this problem that would be great. Look forward to chatting to you. Thanks, Preston |
RE: 1983 944 DME relay or ECU? HELP
DME relay or connection to the reference sensors. You can jump the DME relay with 3 wires twisted together, that will tell you if it is the problem or not. Sounds like the shop really doesn't know what they are working on.
