911 2.7 Trobleshooting Help
hello, I have a 1975 911S with a 2.7 engine. Th engine start Ok, however when it warms up it starts producing white smoke...does anyone have any suggestions as to the possible causes?
Thanks in advance!
Thanks in advance!
A leak down test injects air into the combustion chamber when the piston is at TDC. It is a good indicator if you have bad valves or rings. I would almost bet your valve guides/seals need replacement. The test is done using an air compressor and a special tool
