wheelspacers and bolts are suitable or not?
Recently, I have learned a kind of auto parts of my paramera called wheelspacers and the bolt it required. I have asked several people about the comment of the product and it's vary for forum to forum, some people said that it is bad for the car and increase the unsafty elements of driving. Also I have asked about the brand of the product called BONOSS, I am wondering weather I should buy it or not and the brand is reliable or not.
There are mixed opinions about whether wheel spacers and bolts are safe or not. Generally, there’s no harm in using them, but I don’t know if it’s safer to use them or not. Typically, the size of the bolt you need is longer than the thickness of the spacer. For instance, a 15mm spacer requires a 15 mm or longer bolt. If unsure, you could either check online for more information or talk to a dealer who will advise you if purchasing a wheel spacer is reliable for your car. You can find the bolts you need on scrooz.com.au. They offer extensive product descriptions, and you can even get a consultation with their customer support. Wish you luck!
