| ronaldhostetter |
May 7, 2014 04:35 AM |
30% discount Coupon Code for Kernel for SQL Database Recovery
Corruption of SQL server database is very harmful because you may lose your priceless data permanently. Usually, SQL Server database gets corrupt due to invalid database file header, accidental deletion of data, inaccessibility in drivers and partitions, media corruptions, insufficiency of enough space, virus attacks and various other fatal causes. Although, Microsoft has provided DBCC CHECKDB free utility for resolving SQL server database issues, but often it fails to fix all severe MDF file errors. In such serious situation, you have to look for a professional SQL server recovery tool. Kernel for SQL server repair tool is the best utility that could help you perform a thorough scanning of the corrupt SQL server database to extract all possible data. It is much capable fixing all possible issues of SQL server MDF database files and restore newly database. To use this proficient software, you don't need to know the real cause of SQL server database corruption. Kernel for SQL database repair tool is amazing software which has been developed to fix all the damaged database of SQL server. To offer you the best possible SQL recovery result, this tool is equipped with powerful QFSCI algorithms which helps in easy recovery of every bit of SQL database. The software repair tables, views, triggers, stored procedures, damaged unique keys, primary keys and foreign keys efficiently. Moreover, it also capable of repairing the damaged records, partly damaged records that are saved in separate batch files. Kernel for SQL database repair tool automatically rebuilds batch of SQL database files and enables you to work again on them.
lINK: http://www.freediscountcoupons.net/coupon-code-kernel-sql-database-recovery-corporate-license/
Click the above link to get 30% discount coupon voucher on full version license of Coupon Code for Kernel for SQL Recovery tool.
