82 911 sc transmission
can anyone tell me anything i dont know about removing the tranny from the motor on this thing? ive put the bolts in the flywheel and all that and still it wont release pressure. is there some trick to it or what? what the hell do i need to do!!
RE: 82 911 sc transmission
Suggest buying a Haynes Publishing Repair Manual. Regards Big Bob
Did you remove the clutch spring mechanism yet on the bottom of the transmission? If you don't the release arm is going to keep pressure on the release bearing.
| All times are GMT -5. The time now is 07:14 AM. |
