-   -   911 no fuel pump (https://www.germanautoforums.com/forum/general-tech-27/911-no-fuel-pump-8558/)
cweisser Oct 8, 2009 10:55 AM
911 no fuel pump
have a 78 sc that intermittently wont start... has spark.. no pump... fuel pump/relay replaced...air meter plate looks to be right height... runs great days at a time.. when no start theres no power to pump while cranking...
PorscheDoc Oct 8, 2009 11:16 AM
So there is zero pressure on the fuel plate when it isn't starting? You can turn the key on and find out.
cweisser Oct 8, 2009 11:54 AM
is there a port i hook a guage to then turn key on without crank?
PorscheDoc Oct 8, 2009 01:04 PM
Just pop the air filter cover off, turn the key on (no start), and reach in the air box and feel the fuel plate. It should have pressure when you push against it. You can try it with the key off and see what it feels like with no pressure.
cweisser Oct 8, 2009 02:00 PM
ahhh yes... after i trailered home again... pushed into garage... over bump? then it starts... so yes with key on pump runs and injectors spray when i lift plate... now i suppose i half to wait until no start again?? any thoughts in mean time... thank you
