924 Running Problems???????
Hello, I just got a 1980 924. It would start and run, but as soon as you tried to drive it it would hessitate and die and would not recover. then would not start till it sat for a little while, then do the same thing. I pulled the injectors, and had them tested, and only 2 were good. So i bought 2 new ones and put them in. It has 2 new fuek filters. Now it will start and run at an idle, but as soon as you start drining it dose the same thing, but not as bad, and it will start back up again a couple times, before it wont again. Any suggestions? Thanks
