-   -   944 engine compartment squeek (https://www.germanautoforums.com/forum/general-tech-27/944-engine-compartment-squeek-1758/)
Heinz44 May 9, 2006 01:26 AM
i have an '89 944 and recently have noticed a slight squeek coming from the engine compartment. now i'm thinking on the lines of a waterpump or an altinator. its not the AC cus when i blast the AC, the squeek doesnt get sqeekyer. any ideas?
CTiggerPigglet May 9, 2006 07:12 AM
RE: 944 engine compartment squeek
Is it a rotating squeeking sound?
Does it increase with engine speed (revs)?
:eek:
PorscheDoc May 9, 2006 10:26 AM
Disconnect your power steering belt and Alternator/AC belt, and start the car. If it still squeels, and is coming from the front of the engine, it is probably the waterpump. Stop driving the car immediately and replace it before it siezes and takes out your timing belt.
Heinz44 May 10, 2006 04:57 PM
no revs dont affect it pitch. the pitch stays pretty constant when driving. its slight and you can hear it when you pop open the hood. its hard to notice it over the belt noise
CTiggerPigglet May 11, 2006 07:36 AM
I'd try what PorscheDoc suggests, it most probably is either the alternator, power steering or the water pump or belts.
GOOD LUCK!
