-   -   944 parts car (https://www.germanautoforums.com/forum/general-tech-27/944-parts-car-4002/)
troys49 08-14-2007 04:23 PM
944 parts car
Hey everyone. I have a 1984944. I replaced the trans-axle twice and i feel it's time to cut my losses and make room for my other projects. The car has a little over 85,000 miles on it, and everything with the exception of the trans-axle is in good working order. i have removed some of the parts. Those include:
- the cookie cutter rims
- starter
- alternator
- mass airflow sensor
- throttle body
- electronic fuel control (ECU)
- motor mounts
- distributor cap and rotor
- alternator strut
- brake master cylinder with resevior
- rear view mirror
- and the radiator.
I also have the clutch and the flywheel, but i will not be removing them unless somebody wants them, because of the time it takes to remove them. The clutch has under 10,000 miles on it. Other parts are available, and if someone is interested, post a reply, or you can call Troy at (785) 825-7424 or e-mail me at eschmidt12@cox.net. Time is of the essence as i will be crushing what is not purchased within the next couple of weeks. Thanks!
