-   -   944 T - Getting hot in here! (https://www.germanautoforums.com/forum/general-tech-27/944-t-getting-hot-here-1742/)
johnlanktree May 2, 2006 10:19 PM
My 1986 944 T is spewing hot air into the interior. Can't turn it off obviously-944 constant circulation- so it is a real pain. Air works for a while then gets heated up as well. Less hot air when car is not moving. Duh...
Anyone had this problem?
John
PorscheDoc May 2, 2006 10:23 PM
RE: 944 T - Getting hot in here!
Check the vacuum line from your firewall to the heater control valve. If that is on, then underneath the dash on the control unit is a clip that usually breaks and will lead to hot air all the time. It is about a $2 clip.
johnlanktree May 3, 2006 10:00 AM
Doc,
Vacum line was busted at the T union! You are good!!
Thanks,
JL
PorscheDoc May 3, 2006 02:58 PM
The easy fixes are always nice :)
