944 turbo MPG
Just bought a 944 turbo seems to run rich, getting 15mpg in town if i drive like little old lady and aroung 12 otherwise. manual says 25 around town 35hwy. Any suggestions?....
RE: 944 turbo MPG
When was the car last serviced? Might try a new airfilter. Check Plugs and Cylinder Compressions. Check ignition system.
Regards Big Bob |
RE: 944 turbo MPG
Yea that is bad. I can romp on my turbo and still make 17-18. I would change fuel filter, air filter, check your tire pressure, etc. Are there any modifications to the car? Does it have aftermarket chips in the ECU? If it were running a larger turbo, bigger injectors, etc then expect lesser mpg.
RE: 944 turbo MPG
Good suggestions. I freind of mine runs his on the track and get's better gas mileage. Should be hitting at least 20 on the highway.
RE: 944 turbo MPG
Should be high 20's on the interstate, and around 18-20 around town depending on how you drive.
RE: 944 turbo MPG
My buddy must be driving faster than the average bear.:D
RE: 944 turbo MPG
ORIGINAL: Hot911TT My buddy must be driving faster than the average bear.:D |
RE: 944 turbo MPG
Another thought what grade fuel do you run on. I find the higher grades give me much better gas miileage. Regards Big Bob
RE: 944 turbo MPG
I think the 944T should be running on high grade
RE: 944 turbo MPG
Hi grade would certainly be better. Big Bob
