996 headlamp bulb replacement
How do you change headlamp bulb on 996 - appears to be a completely sealed unit are there hidden fixings? and what bulb do I need (H1 ??) it doesn't have xenons. thanks
RE: 996 headlamp bulb replacement
There is an allen tool in your toolkit. Pull the carpet on the inside wall of the trunk (on the side you are replacing, and you will see a rubber knob. Pull the knob out of the hole. Insert your allen tool. Turn it until the headlight pops out. Pull out the headlight, pop off the back cover, replace the bulb. Installation is opposite of reverse.
