996 rear shock tower nut torque
Iwant to removea DAS Sport roll barfrom my '04 996 C2. The rear mounting points are at the shock towers and are heldonto the studs with3 nuts. I'd like to torque the nuts properly but don't know what the torque should be. I think the 993 was about 20 ft-lbs, and the 996 GT3 is 24 ft-lbs, so I'm guessing the 996 C2 will be in the same range. Any info would be helpful.
RE: 996 rear shock tower nut torque
Right around 24ft/lbs is fine.
Thanks Doc.
