bleeding order
on my 944 im not sure where to start with bleeding i know when u replace the slave cylinder or the master cylinder u have to bleed the whole system i just dont know what to do first?
RE: bleeding order
The bleeder for the clutch system is only on the slave, when you bleed it there, it does the entire system.
RE: bleeding order
so the order doesent matter?
RE: bleeding order
What do you mean the order? The order of what? If you replace the master clutch cylinder OR the slave cylinder, you have to bleed the clutch system. If you replace the brake master cylinder, you have to bleed the brake system.
