Convert OLM into PST Files
Old 06-21-2017, 05:08 AM
Default Convert OLM into PST Files
Conversion of Mac OLM files into Windows PST files has never been easier. Thanks to OLM to PST Converter Export MAC Outlook Emails to MS Outlook PST you can export emails, contacts and calendars into Windows’s compatible format. It exports hierarchical OLM structure into PST file and make it readable. In addition, it preserves non English UNICODE characters and gives proper attention to nested messages.This tool is able to convert address book in OLM format into “Contacts” folder of MS Outlook. In the same way, this software helps you to process Unicode characters in over 60 address books of OLM without causing loss of any data.This software is user-friendly and the completion of the whole conversion process is only a few clicks away.
Old 06-28-2017, 12:19 AM
You are facing this issue because Outlook for Mac uses OLM file format to store all of its data while Windows Outlook uses PST file format.
The Outlook 2016 that you are using, wont be able to read the OLM file created by your Outlook for Mac 2011.
To solve this problem, you need to convert the OLM file into PST format so that you can access the data stores in that OLM file through Windows Outlook.
There are many file conversion tools available that can convert OLM files into PST files. You can do a web-search and find a converter that suits your need. Here is one converter i found: https://goo.gl/33rCZ1
Alternatively, if you need to access only some of the data, then you may employ the manual method:
* Create an IMAP account,
* Add that account to your Outlook for Mac account.
* Transfer the required data to that IMAP account from your Outlook for Mac.
* Now add that same IMAP account to your Windows Outlook and synchronize.
* The data you transferred from outlook for Mac would be added to Windows Outlook via that IMAP account.
But the above mentioned procedure is only feasible if only small amount of data is to be transferred otherwise the entire procedure would become very complicated and tedious. If you need the entire OLM file database on your Windows Outlook, then you need to use a conversion tool.
I hope this suggestion helps.
Old 07-08-2017, 12:46 AM
Advance OLM to PST Converter is a best tool which efficiently repairs the OLM file and recovers all the items of Mac Outlook mailbox into PST format. Now users can easily migrate into MS Outlook environment. This software saves the exported data efficiently from inaccessible or damaged OLM files. One can export a single Mac outlook mailbox to a MS Outlook with this tool. This can also export several OLM files to MS Outlook in a sole conversion cycle. This software quickly retrieves mails, contacts, calendar items, hyperlinks, attached files and other data from OLM files.
See more info at:- Convert Mac OLM to PST Format.
Old 05-30-2018, 12:14 AM
Mac OLM files to PST conversion turned out to be a nightmare for me. I had all my mails, which were supposed to be in separate folders, dumped to a single mail folder. Moreover, the mails were full of deformed characters, indicating some serious corruption.
I started searching a new paid tool for the same. After a lot of searching, found OLM to PST converter Ultimate by GLadwev. This tool offered free conversion of up to 10 mails per folder. It migrated all my mails safely with zero corruption. The conversion speed was not compromised even by a bit. http://www.gladwevsoftware.com/olm-t...rter-ultimate/
Old 07-31-2018, 01:26 AM
Download OLM to PST Converter Software to convert Mac Outlook OLM file in Outlook PST and in some more other file format like EML, MSG and MBOX. OLM to PST Converter Tool allows export emails, messages, contacts, appointments, journal and other items stored by Mac Outlook email client application to an Outlook PST file format of windows operating system.
kennthwatson
05-08-2019 02:04 AM
jameshhock
11-28-2018 04:59 AM
RogerBarraza
11-13-2018 06:04 AM
MikeSnyder
02-13-2016 03:53 AM
ThomasAndres
02-09-2016 11:16 PM
Quick Reply: Convert OLM into PST Files
