NSF to PST Converter Tool
With the help of Lotus Notes to Outlook converter all consumers can recover Lotus Notes NSF file and convert NSF file to PST, EML and MSG format with whole versions of Lotus Notes NSF and Outlook file.
See More: http://www.nsf-to-pst.com
Fabulous solution of Lotus Notes file conversion great fully recover NSF file and export NSF file to PST, EML and MSG format with whole versions of Lotus Notes NSF and Outlook file.
Read More:
NSF to PST Converter to Recover, View & Convert NSF to PST
Read More:
MS Outlook stores its data in PST format whereas Lotus Notes uses NSF format for the same. In order to convert NSF format into PST format we may use conversion tools like NSF to PST Converter.
There is a manual method as well for transferring Lotus notes data to MS Outlook, using Export/Import feature in Lotus Notes or MS Outlook, but this method is very complicated and becomes very tedious if large amount of data needs to to transferred.
Whereas using the converter is very easy, quick and precise. This conversion tool can even convert encrypted NSF files into PST files.
Some Of Its Salient features are:
# Convert NSF files in bulk
# Convert all data including calendar, tasks, contacts and emails.
# Keep original files intact
# Compatible with all Windows OS and all versions of MS Outlook and IBM Lotus Notes
In order convert Lotus Notes file format to MS Outlook file format, you need to Export the data from the Lotus Notes and then you need to Import that data to Outlook. It is a quite a lengthy and complex procedure that involves, a lot of technical steps.
For easy and fast procedure I would suggest you download the NSF to PST Converter from the Internet. This tool can remove the encryption from Lotus notes. And it has special date range feature to select the specific emails from the desired date.
You can try it free versions also.
You can convert your Outlook .pst file to Lotus NSF by using nUpgrad.exe 3. it is a part of Notes migration tools.
If this manual method doesn't work try to use Third Party Tools, you can download PST to NSF converter, It will bring entire email items like Emails with all their meta-attachments.It is quite safe and fast. and it has some remarkable features also.
Before buying you can try its Free Version also.
Truly, Notes to Outlook converter is an efficient software to migrate Lotus Notes database to Outlook platform. So, users can use Kernel for NSF to PST converter software that impeccably converts NSF file to PST, Text, HTML and RTF format. This tool transfers NSF mailbox like messages, attachments, appointments, images, notes, journals, address books, tasks and additional folders. Get more to visit here - NSF to PST Converter to migrate emails from Lotus Notes to Outlook Platform
NSF to PST Converter Tool is simple software to convert from NSF file such as calendar, address book, draft, notes, meeting, task and Outbox into PST Outlook like MSG, EML, MBOX, CSV, HTML, and EMLX with all details.
Get more information:
NSF to PST | NSF Converter | NSF to PST Converter
#10
