is it hard to change the spark plugs on a 1999 996? any pointers? thanks
Old Mar 4, 2006 | 11:54 AM
ericurena's Avatar
Default is it hard to change the spark plugs on a 1999 996? any pointers? thanks
Old Mar 4, 2006 | 06:39 PM
Default RE: is it hard to change the spark plugs on a 1999 996? any pointers? thanks
On the NA? It is incredibly easy. Turbo requires the removal of the bumper cover and intercoolers.
Slide the rubber boot back on the electrical connector and disconnect the electrical plug from the coil pack. 2 5mm allen bolts hold on each coil pack. Remove the bolts, pull off the coil pack. Spark plug socket and the right length extension is all you need from there out.
About an hour job.
Old Mar 4, 2006 | 06:41 PM
OH, and you can use just an L key allen, but i cut off a short piece of the allen key and inserted it into a 5mm 1/4" drive socket so i can use my rachet. Breaks the bolts loose a little easier anyways.
Old Mar 4, 2006 | 10:03 PM
You probably have figured it out by now, but 2 10mm (head size) bolts hold on the small heat shields over the coil packs.
HP=$$$
Oct 1, 2007 10:49 PM
PorscheRulz
Dec 25, 2006 08:55 PM
goebels97
Jul 14, 2006 07:41 PM
pioneer
Mar 23, 2006 10:53 PM
ericurena
Feb 26, 2006 09:54 PM
