hi again have another problem
the only thing i can say is my clutch is stuck to the floor does anybody know the solution?
RE: hi again have another problem
Well, most likely you have a bad hydraulic system. I would replace the clutch master cylinder, clutch slave cylinder, and the hose the runs between the two. You can look and see if any one of those is obvious as the failure point (leaking fluid) and replace just that piece, but typically when 1 goes, the others aren't far behind.
yeah thats what i thought it was. so it could just be a leak in the lines?
It could be the metal/rubber line connecting the two, but if that isn't it, then it is one of the cylinders. Bite the bullet and replace it all.
Is there a cotter pin connecting the two, am less familiar with the 944, but it happened on my 1980 911SC and all it turned out to be was a bad pin in the pedal assembly....easy fix.
Steve |
Clutch cable adjustment? Does seem a little severe for this though.
