PorscheDoc |
11-02-2010 02:13 PM |
Open the convertible top until it retracts about 2 inches from the windshield. Get out, remove the cable on each side of the top (rear), it is just a ball and socket and will pop off the lower ball joint. Unclip the rear fabric piece by pushing down on it. Once all that is loose, carefully fold the rear of the top forward. Remove the cubby and carpet by twisting the black clips 90 degrees. If you have the bose speaker box, then unclip the electrical connection on the passenger side first. Once that is out of the way, turn the 5 clips 90 degrees or so on the black cover underneath and there is the engine. Sounds like a lot, but in reality takes about 30 seconds to get to the top of the engine bay.
To get to the front of the engine, push the seats all the way foward and recline them forward. After removing the carpet from the previous step, you will see the top of the front carpet section (piece that is behind the seats), there are 4 plastic nuts holding the carpet in place on the top. Remove those and you can pull the carpet out. Then you are looking at a metal panel with about 10 10mm nuts/bolts. Remove those to access the front of the engine. NOTE: The edges of the front cover are EXTREMELY SHARP, so remove and install with care. I have gashed fingers open more times than I care to count on that stupid cover when in a hurry.
