Sponsored by:
Sponsored by:
How to convert OLM to PST Conversion Tool?
Old 07-21-2017, 05:01 AM
OLM to PST Conversion is common among Outlook for Mac users.
There are two methods of conversion,
1. Manual Method
2. Using file conversion tool Method.
Both of these methods have been described in detail in this article. Ways To Convert OLM File Into PST Format.
  #12
Old 10-31-2017, 12:02 AM
Rawatsonika4u's Avatar
Banned
OLM to PST Converter is a best tool which efficiently repairs the OLM file and recovers all the items of Mac Outlook mailbox into PST format. Now users can easily migrate into MS Outlook environment. This software saves the exported data efficiently from inaccessible or damaged OLM files. This can also export several OLM files to MS Outlook in a single conversion cycle. This software quickly retrieves mails, contacts, calendar items, hyperlinks, attached files and other data from OLM files.
Get more info at:- Mac OLM to PST Conversion.
  #13
Old 12-21-2017, 06:03 AM
jameswold's Avatar
Default OLM to PST Converter Tool
The simplest and smartest way to convert OLM to PST is using the OLM to PST Converter Tool. It convert the entire mail data either it is mails, contacts, calendars, attachments, etc directly from OLM files to PST files for Outlook. It run and support both Mac and Window operating system and can be used on any of either for conversion. One can try its free trial version which allow you experience migration before using this tool completely.
For more details: http://www.olmtopstconvertertool.net
  #14
Old 04-23-2018, 01:56 AM
sentluis31's Avatar
Download free OLM to PST conversion tool, the free demo version to judge the potential of the tool. Once it manages to impress you then make the online transaction and buy its full version. You can also download free demo version: http://www.recoverydatatools.com/olm-to-pst-converter.html
  #15
Old 08-20-2019, 02:47 AM
Amaya_S's Avatar
I would suggest you best OLM to PST Converter which is a very effective software to Migrate Mac OLM to PST file formats. This software provides a multiple PST file format. The OLM to PST converter is the best and perfect choice for migrating mac mail.
The tool has the best feature of OLM to PST Converter:-
  • Convert OLM file to Multiple files formats
  • Complete conversion of OLM file to PST
  • Complete and instant preview of OLM file
  • Recover Corrupted or HealthyMultiple OLM files
  • Supports all MBOX 25+ platforms
  • No Data Size Limitation Of OLM File
  • Split up Large OLM file by Size
Visit for more details:- Mac OLM to PST Converter - 3 Steps Solution - OLMCon
  #16
Old 08-03-2021, 05:37 AM
dannyd's Avatar
Ocasionalmente, es necesario convertir los correos electrónicos de un tipo de archivo a otro. Uno de los inconvenientes de convertir archivos OLM a archivos PST se puede encontrar de la misma manera. Vartika OLM Converter Tool convierte archivos OLM a PST, incluidos correos electrónicos, contactos, calendarios, tareas, notas, borradores y otros elementos. Proporciona una vista previa de la conversión de archivos OLM para garantizar su satisfacción y funciona con todas las versiones de archivos de Outlook, incluidas 2019, 2016, 2013, 2010 y versiones anteriores. Descargue una versión de demostración del software para probar su funcionamiento antes de comprar la edición completa del software de conversión de OLM a PST, que se ofrece a bajo costo.
Saber más info- vartikasoftware.com
  #17
Old 12-17-2022, 03:11 AM
Aria's Avatar
Default Export OLM Files to PST
When there are more than 20 email files in *.olm to *.pst along with the attached documents. Use the OLM to PST Converter Software for the same. At once multiple files can be switched to Windows Outlook PST. Do not try to open the OLM files in the Windows OS Outlook, since the OLM does not support it and might corrupt the files. Thus, use the trial version to convert around 20 files in the OLM extension to PST and then effortlessly convert OLM to PST in a few clicks.
Also, get the application: https://www.macuncle.com/olm/converter/
  #18
Old 01-05-2023, 09:24 PM
alecksteve's Avatar
Default Migrate Mac OLM file to Outlook PST
Download one of the best Mac OLM to PST Converter tools to convert Mac Outlook OLM into Outlook PST format. It is best for users to convert Mac OLM data like email, contacts, attachments, calendars, etc to Outlook PST format without any data loss. SysVita OLM to PST Converter Software Migrate OLM file data into multiple formats like PST, EML, EMLX, MSG, HTML, VCARD, MBOX and export OLM to Cloud Office365, Live Exchange Server, Live Outlook, etc. Also, any technical and non-technical user can use this tool very easily. It is a simple and best solution and export OLM files to Outlook PST data files in a single process. The software supports all MS Outlook versions like 2021, 2019, 2016, 2013, 2010, 2007, 2003, etc.
Also, get the application: https://www.sysvita.com/mac-olm-converter.php
chadkeane
01-05-2023 09:27 PM
matthewrenshaw
10-28-2022 03:40 AM
Seejarclark
10-12-2022 01:41 AM
Seejarclark
05-29-2018 12:19 AM
Quick Reply: How to convert OLM to PST Conversion Tool?
