Humidity inside instruments
Hi Folks
Having a problem with humidity inside the cockpit instruments (911-964). After about 20 min driving condensation on the glass. On one instrument the film inside the glass detached from the glass. Can the instrument be removed easily? Can anybody help? Thank you maltow |
RE: Humidity inside instruments
Just pull the gauge straight out towards you, and it will pop out. It is held in by a rubber seal, which can be kind of tight, but they do just pull out of the dash. To open them, you have to pry the metal face trim off with a screwdriver (carefully), enough so that it and the glass will pop off the rest of the gauge.
