Issue with shifter
Hi,
I am new to this form and to porsche. I just bought a 2002 911 carrera coupe. I got a short shifter and it is a 6 speed manual. Few weeks back the while driving (shifting from 1->2) the shifter just got loose and the car wont go into any gear. I had to get the car towed. I took it to the porsche dealer and they fixed it. They just said that the bearings went loose in the shifter. Nothing wrong with the gear. I have driven a manual before and never had such issues. The dealer said that may be I was slamming the shifter too hard. But I think otherwise. Even if I slam it a bit hard, is the shifter supposed to just get loose? What am I doing wrong? These days I figured out that sometimes when I try to shift to first gear, the shifter somehow stays in middle. I mean not in 1st gear nor in neutral. I have to really concentrate to put it into first. Is there something wrong? I hope I am doing sthin wrong rather than something wrong with he car. Please advise! thanks, mayukh |
RE: Issue with shifter
You should be able to shift any way you want to short of slamming it and intentionally attempting to hurt the car. Even then it would be pretty hard to loosen the shifter if installed correctly with the right parts.
Try getting a second opinion. Maybe there's a good independent garage somewhere near you. If the dealer you took it to is also the one that sold you the car they may be wanting to avoid stepping up to the plate and helping you with this issue. It is a safety issue and they should be obliged to correct this for you at their expense. just my .02... |
Sounds like bad shifter cables. There are 2 cables. One for R, 1st, 3rd, 5th, and the other one for 2nd, 4th, and 6th. Its normal for some resistance while changing into 1st gear if you arent stopped, or close to a stop. Bearings getting loose in the shifter sounds a little fishy to me. The problem with getting a second opinion is the labor intensive process of checking the cables. If it is a bad cable, replace them both at the same time even though only 1 is bad.
Good luck, Kevin |
I bet the bottom plastic shifter bushing broke and they just replaced it since it is a known failure point. There is nothing else that could cause your shifter to act like that, not even the cables.
