o2 sensor 928
is there any service you can do on a o2 senor? can you show a diagram it's placement?
RE: o2 sensor 928
any service or cleaning to improve a o2 sensor on a 1984 928? can you show diagram as to it's placement? approx cost if needed replace?
RE: o2 sensor 928
There is no service you can do to an O2 sensor. It is under the passenger side floorboard, between where the 2 exhaust pipes come together. Takes about an hour to replace or so. The wire runs through a grommet on the passenger side of the central tunnel, and into the DME/fuse area.
| All times are GMT -5. The time now is 05:54 AM. |
