porsche 964 need to lower
have a 1990 porsche 964 with twin turbo engine in it the front need sot be lowered quite abit
as you can see in the pic i turned the coil overs a fair bit but no change is there a diff way to do it [IMG]local://upfiles/6347/43279328C89043CFB39A530BA713EF74.jpg[/IMG] |
RE: porsche 964 need to lower
Lord, what sized rims are those? The only good way to properly lower the car is to install a set of coilovers. The factory units only have so much adjustment. It appears your rim choice might be a limiting factor as well, Porsche does not recommend over an 18" wheel on a 964.
they are 19" tires on rear are 300-30-19"
car has factory coil overs but doesnt seem to help lower the car at all |
ORIGINAL: porsharu they are 19" tires on rear are 300-30-19" car has factory coil overs but doesnt seem to help lower the car at all |
