PST to NSF Converter
Outlook to Lotus Notes Conversion by PST to NSF Converter Tool is crackerjack utility which efficiently and instantly converts Outlook PST files into Lotus Notes NSF files. With this utility, you can faultlessly access Outlook data by using Lotus Notes. It allows users to convert all the files and mailbox items, such as notes, emails, contacts, calendars, sent items, appointments, alarms, email properties, images, journals, text formatting, tasks, attachments, deleted items and each and every separate folder you had created in PST before. Without compromising even a little bit of data, PST to NSF Converter can help users to successfully migrate from MS Outlook to Lotus Notes. It also supports conversion of Unicode characters and it is compatible to All Lotus Notes version and Microsoft Outlook 2016, 2013, 2010, 2007, 2003, 2000, 98 and 97 on Windows 10, 8, 7, Vista, Xp, 2003, 2000 and 98.
There is an easy way to convert the PST files in NSF format that is by using freeware converter tool. This can help you in saving your time period. Check it out the cost-effective tool and convert you corrupt data(NSF) into fresh and all new data files(PST). Before purchasing it you should understand the process To Migrate PST to NSF file smoothly. This article will definitely help you to understand the Software and its procedure.
Before purchasing any paid software for PST to NSF conversion, you should use the nUpgrade.exe utility. It's a part of Lotus Notes migration tools. By using this tool, you can import mailbox content from Outlook to Lotus Notes without using any 3rd party tool. Refer to this article to know how to use the nUpgrade.exe utility - Import Outlook to Lotus Notes - Convert PST to NSF
Get a quick and safe conversion solution to convert your all corrupted or normal PST files into NSF. With PST to NSF converter tool users can repair the corrupted PST files and then convert files into NSF file format. This tool allow users to select the data range and then convert all selected PST files into NSF without causing any data loss and alteration on the data files.
Download free demo version of this tool, here:- PST to NSF converter perfectly converts PST files into NSF format |
