Recover the inaccessible or damaged MDB or ACCDB files
Old 03-17-2016, 01:08 AM
Default Recover the inaccessible or damaged MDB or ACCDB files
Access file Recovery Software allows you to recover your Access files or your Access database, it can also repair and fix corrupt Access databases. It can restore the table structure, data, key elements (primary key), field size, original date, validation rules, etc.this Software allows you to recover corrupt or damaged files that were created with Microsoft Access 2003, XP, 2000, 97 and 95.
For more:- MS Access Recovery Tool Repair/ Restore/ Fix Corrupt Database .MDB Files
Old 05-07-2016, 04:30 AM
MS Access database files (ACCDB, MDB) can get corrupted due to various reasons, It's a very common problem. So you can repair it with the help of inbuilt "Compact and Repair" tool. But if after using this tool, you are not able to repair the corruption issues, then you can try any third party MS Access File Recovery Tool.
Read more details about manual and third party tool here: https://goo.gl/HTuj9Z
Old 11-10-2016, 10:54 PM
Thumbs up How to repair Access database file?
There are few easy manual tricks which can repair Access database file without requiring any paid solution. Microsoft Access provides you a built-in repair utility, known as Compact and Repair, to repair Access database. Microsoft also provides you JetComp.exe which can be used to repair Access database. There's one more thing you can try here. You can import corrupt database into a new database. I can share this blog post here which contains useful information: Repair Access Database with Compact and Repair Utility | N. Sem's Blog
If the manual trick fails or don't work, then only you should consider using professional Access Database Recovery tool. It supports corrupt Access database saved in both MDB and ACCDB format. You must download free demo version of this tool before purchasing its licensed version. I hope the shared information would be helpful here.
Thanks and best regards.
Old 01-31-2019, 02:00 AM
Access database gets inaccessible when encounters any corruption issue. This corruption issue usually occurs due to several of the reasons but it doesn’t mean you can’t resolve this. In the case of repairing the inaccessible or damaged MDB or ACCDB files you need to try the easy fixes. To know about the fixes just take a look over this informative post:
read more:
[Massive Guide] On How To Fix Corrupt/Damaged Access Database
MikeSnyder
11-17-2018 03:57 AM
johnbutlor
04-03-2018 12:05 AM
johnbutlor
07-26-2017 01:46 AM
johnbutlor
02-24-2016 10:29 PM
abelmartin002
05-23-2015 01:48 AM
Quick Reply: Recover the inaccessible or damaged MDB or ACCDB files
