Use Split PST Technique
Try to discover new way of handling large size Outlook PST data using Split Technique that will help you to break your large size containing PST file from Outlook account in some small PST files, so that you can use them individually. Its not a big task to do and the tutorial: Split Outlook PST file will make it easy for you.
I had the same problem with oversized Outlook PST file some time ago, so I found this PST Split http://www.split-pst.com tool. This software split all PST mailbox data like Calendar, Contacts, and Journals, Email Folders (Inbox, Deleted Items, Outbox, Sent Items, and Drafts etc.). It also supports all MS Outlook versions 2016/ 2013 / 2010 / 2007 / 2003 / 2002 / 2000 / 98 / 97.
Stellar Phoenix Split PST Tool ? Split Large Files into Small Ones excellent utility which divides large PST file into manageable and smaller PST files as per the specific criterion like size, date, folder and email id, and protects them from any corruption issues because of file size limits.
How to split PST file?
If you're looking for a free solution to split PST file, you should try few easy manaul tricks. There's no need to use any paid software or any other cost. All you need to use is Outlook client, that's it. It has few built-in features which you can use here to transfer mailbox content from one PST file into two or multiple new PST files. Refer to this blog post - Few Easy Ways to Split PST File into Multiple Smaller Parts | N. Sem's Blog
Through this blog post, you'll learn how to use Archive, Import & Export, and Move to Folders features. Also, you can use drag & drop feature of Outlook client. If the manual tricks shared in the above blog post fail or don't work for you, you should use a professional solution. Download free demo version of PST Split software to split PST file into multiple smaller parts. It provides you different ways: Split PST file by size, Split PST file by date and Split PST file by sender's email id. By using demo version, you can save first 25 email items of each mailbox folders of selected PST file into new PST files. Thanks and best regards. |
In order to split Outlook file, try of Split PST Download Tool, easily open software for any users. This is completely capable to split numerous Outlook PST files. Supports all previous and latest versions of Outlook. Furthermore, all PST based email applications can use the software to split many PST. Get details: https://www.sametools.com/split/pst/
victoriyalove.com - direct link to the best dating site! Only real girls are ready for meetings! Try it and you will be surprised!
The Best Technique to split the large PST is KDETools PST Splitter. This tool is the best and advanced features tool.
More Details: Split PST Tool to Divide/Split Large Outlook PST File into Smaller Parts |
I am really impressed by this Software. It work amazingly to split your PST file as your requirements.Its a time consuming application.
For more info: https://www.toolsbaer.com/pst-split/ |
When the size of the PST file exceeds the maximum file size limit, it could push you towards unfavourable situations of data loss and broken data items. The more a PST grows in size, the more it becomes a major reason of concern for Outlook users. So, you must adopt some methods to maintain Outlook PST file’s size and control your system from running out of space.
https://www.recoveryandmanagement.co...es-in-outlook/ |
Try Cigati Outlook PST Splitter Software to Break large-sized PST Files of Outlook into Smaller and Manageable PST Files in a safe mode. The tool allows users to divide large-sized PST files of outlook and performs swift splitting of selected PST files within no time.
