Water Pump
Just a quick question,
The water pump for the boxster are all the same from 97-04 regardless if its 2.5, 2.7 etc? Im ordering parts online. any suggestions on where I can get a good deal? thanks in advance |
RE: Water Pump
Yes it is all the same. Also the same pump for the 996 as well. If you need one, give me a shout, I have them in stock.
RE: Water Pump
Do you have to bleed the system after replacing the water pump or is it just recommended?
