Wider Tires For 2002 boxster
Old May 11, 2008 | 01:48 AM
jimmie325's Avatar
Default Wider Tires For 2002 boxster
Hi i have a 2002 boxster S, I'd like to make the tires look wider ; the tires are front 205/50-17; rear 255/40-17; what size tires can i use so the tires look wider as much as possible without effecting the cars performance and safety. id like to keep the 17" wheels .thanks
Old May 11, 2008 | 03:36 AM
Big Bob's Avatar
Default RE: Wider Tires For 2002 boxster
To be honest, you need to fit the right size tire for your rims, and run with the correct aspect ratio. There are handling/safety risks in not staying in the right parameters.
Take a look at Victor Equipment Website, and Yokohama Advan Website for the possibilities.
Regards Big Bob
Old May 11, 2008 | 08:39 PM
Hot911TT's Avatar
Typically you can go up one size. You should be fine with 265's
Old May 22, 2008 | 12:58 AM
jimmie325's Avatar
the front are 205/50 do i go 215/50 thanks
cpd777
Dec 31, 2007 05:09 PM
SS MPSTR
Oct 11, 2007 07:15 PM
vbanh
Aug 12, 2007 02:53 PM
ygfamily21
Mar 4, 2006 12:45 PM
wtam
Dec 14, 2004 02:11 PM
