Wider Tires For 2002 boxster
Hi i have a 2002 boxster S, I'd like to make the tires look wider ; the tires are front 205/50-17; rear 255/40-17; what size tires can i use so the tires look wider as much as possible without effecting the cars performance and safety. id like to keep the 17" wheels .thanks
RE: Wider Tires For 2002 boxster
To be honest, you need to fit the right size tire for your rims, and run with the correct aspect ratio. There are handling/safety risks in not staying in the right parameters.
Take a look at Victor Equipment Website, and Yokohama Advan Website for the possibilities. Regards Big Bob |
Typically you can go up one size. You should be fine with 265's
the front are 205/50 do i go 215/50 thanks
| All times are GMT -5. The time now is 09:53 AM. |
