| 944SROK |
Mar 9, 2009 12:04 AM |
Check engine light w/ normal oil pressure
1) I recently purchased a well maintained 1988 944/2 with 168K miles, and I love it. Last week the check engine oil pressure light began coming on as the engine warms to operating temperature and oil pressure drops below 4 bar when idling down. Oil pressure range that I'm getting, according to the gauge, is 4.5-5 bar when cold, 2.5-3+ bar when fully warmed at idle. I believe that these pressures are where they should be, IF the gauge is indicating correctly. Any suggestions as to why the check engine/oil light is coming on?
2) The car is due for an oil change. The previous owner used Valvoline 10W-40W Max Life synthetic blend. Is this a good oil for a 944, or should I use a fully synthetic (e.g. Mobil 1)? I plan to use Mahle oil filters. Any suggestions?
