73 911 T Targa - oil light blinking
I need help in resolving an issue that as soon as I turn the ignition on, the oil light on my dashboard indicator flashes, and it will stay flashing at all times. As the light flashes,I can also hear the flasher relay ticking or it sounds like the hazard light is on but it's not. I have checked all the oil system electircal wiring and all checks good. Oil prressure and temp are normal.
Please help!! rescober |
RE: 73 911 T Targa - oil light blinking
The only thing I could suggest would be to check your fuses and the flasher relay. It could be as simple as that. Not much elseI can think of. Hope you find the problem.
