Battery Died and trunk will not open HELP!
I have a 1999 996 cab,i haven'tdriven it very much. There's no Electrical response
Is there any other way to open the trunk/hood. Using the door key is not helping the Battery is totally died.... is there a manual way to open the hood and get to the battery... |
RE: Battery Died and trunk will not open HELP!
There should be a release cable under one of the headlights. You need to use something to fish it out. If you do a search at renntech.org you will find it.
thanks,I will try to find it
It was there!..... there is a small cable on the passenger side .....I was able to reach mine from the bottom.... there's an opening large enough to eachyour hand in and grab the cable.Had to jackup the car and use a flash lite to see it.
thanks, Function12 and Doc |
