Check Engine Light
I have a 2001 996 911. The check engine light recently came on. The car seems to be running fine. Is this something I need to address ASAP or is it more of a reminder to get the oil changed?
Thanks |
RE: Check Engine Light
Likely cause will be the MAFS Sensor. Ie Mass Airflow Sensor. Or one or more of the Oxygen Sensors in the exhaust system. You need a litle diagnostic help to sort this out.
Thanks and Regards Big Bob |
