-   -   Gap in instrument cluster, please help! (https://www.germanautoforums.com/forum/porsche-911-8/gap-instrument-cluster-please-help-2829/)
911fiend Feb 7, 2007 03:31 AM
I just picked up a 2001 996, and I noticed an unsually large gap between the instrument cluster and the dash. As anyone seen this before who might know how to fix it?
[IMG]local://upfiles/3106/EF2E967715824D4A884842466554B8DB.jpg[/IMG]
PorscheDoc Feb 7, 2007 11:02 AM
RE: Gap in instrument cluster, please help!
Some gap may be normal, I can't tell based on your picture and angle of the picture. If it is up a little, then it probably isn't snapped down all the way. You need to remove the torx screw from behind the hazzard button (pull off the trim piece with a small screwdriver), then push it down until it snaps into place and retighten the screw.
I take it there are aftermarket color gauge faces or carbon fiber trim around the gauges? It has to have been removed at some point.
911fiend Feb 7, 2007 03:10 PM
Yes, it's got aftermarket gagues so it was definetely removed. I tried snapping it back down without removing the torx screw but that didn't work. So I'll remove it and try again. Thanks PorscheDoc!
