Help with annoying 964 hesitation
My 964 C4 has a hesitation when I depress the throttle hard. The engine will hesitate or bog for a full second or two then start to accelerate. It also happens when cruising in gears 2-4. I also notice an intermittent rough idle. I have new plugs, wires, caps, and rotors. The primary distributor belt was replaced last winter. DME relay and fuel filter on order. What else could be causing this?
If the Air Flow Meter is the culprit can the AFM be repaired or do I have to spend $1279.00 for a new one? I noticed that my oldplugs were white. Is this a good indication of the AFM makingher run lean and causing the hesitations?
