Help with annoying 964 hesitation
My 964 C4 has a hesitation when I depress the throttle hard. The engine will hesitate or bog for a full second or two then start to accelerate. It also happens when cruising in gears 2-4. I also notice an intermittent rough idle. I have new plugs, wires, caps, and rotors. The primary distributor belt was replaced last winter. DME relay and fuel filter on order. What else could be causing this?
RE: Help with annoying 964 hesitation
Might want to pull the AFM and check to make sure the potentiometer arm is not riding in a groove on the strip.
If the Air Flow Meter is the culprit can the AFM be repaired or do I have to spend $1279.00 for a new one? I noticed that my oldplugs were white. Is this a good indication of the AFM makingher run lean and causing the hesitations?
There is a really good video on youtube called "Rejuvenating a Bosch Motronic AFM". I'm pulling mine ASAP to fix it. Is there anything else I should be looking at?
| All times are GMT -5. The time now is 02:48 AM. |
