-   -   Help with Mirror (https://www.germanautoforums.com/forum/porsche-911-8/help-mirror-1565/)
surjones Mar 10, 2006 09:06 PM
Help with Mirror
Okay, So I own a 1991 Carrera and for some reason the mirror on my driver side is not working properly. In order to move it you need to push down hard and rotate, and you can lift it off the base with ease, which the you can't do to the other. Any ideas what it might be, or what I might do to fix it? I am a major newbe, so thanks for the patients.
thanks
surjones Mar 13, 2006 03:10 PM
RE: Help with Mirror
Okay guys need any help, mirror is on it's last leg.
thanks in advance
PorscheDoc Mar 13, 2006 07:29 PM
Sounds like the motor is on its way out possibly, or something is binding up behind the glass.
surjones Mar 13, 2006 11:50 PM
It is the entire mirror. Not juust the glass. You can pick the who peice off of the base which sits on the Car.
PorscheDoc Mar 14, 2006 12:20 AM
Oh, lol. Ok, if you turn the mirror on it's base (as if you were folding the mirror housing against the window, or away from the window, there should be a small allen screw once it is rotated in the correct position. Tighten that up and see what happens.
