Help! PSM and ABS problems
hi i'm having problems with my 01 996 turbo. when i start the car everythings fine but after driving for a few minutes the computer suddenly tells me "PSM off" n "ABS off", " "go to workshop" but after shutting of the engine and turning it back on everythings normal again. but the same problem comes up again after a while, any suggestions on what could be wrong? thanks in advance!
RE: Help! PSM and ABS problems
Either you have a brake light switch gone bad or a bad MAF sensor. Since it clears itself, I am going to guess a bad brake light switch.
ok thank alot!
| All times are GMT -5. The time now is 11:24 PM. |
