OEM Blaupunkt Stereo Removal?
Old May 8, 2007 | 04:10 PM
Porsche3045's Avatar
Default OEM Blaupunkt Stereo Removal?
My 1986 911 currently has the OEM Blaplunkt Monteray stereo, however the U button does not work, neither does the the display. I have sourced a replacement stereo unit of the same model.
Does anyone have any tips for removing the head unit? It appears there are 4 small holes at each corner -- which I'm told require a special tool or slightly modified coat hanger as the 'puller device'.
I would gladly accept any tips or advice for this removal procedure.
Thanks
Old May 8, 2007 | 05:57 PM
Default RE: OEM Blaupunkt Stereo Removal?
You should be able to get it out with anything that you can stick in the holes, such as a coat hanger. It sometimes takes a little wiggling, but you should be able to reach under the dash and help persuade it from the back side.
Rob Shapland-Hill
Apr 22, 2012 10:03 AM
grenade inspector
Feb 17, 2010 12:46 PM
vender
Mar 27, 2009 10:19 PM
Daves911sc
Sep 25, 2008 11:46 AM
Daves911sc
Sep 24, 2008 01:31 PM
